How to Change the Default SSL Certificate in LabVIEW
Updated Sep 1, 2026
Other
  • NI Web-based Configuration & Monitoring Utility
This article explains how to replace the default Secure Sockets Layer (SSL) certificate used by LabVIEW and the NI Web-based Configuration & Monitoring Utility. Use this procedure when deploying a trusted Certificate Authority (CA)-signed certificate or a sefl-signed certificate for the System Web Server or Application Web Server.
  1. Navigate to localhost:3582 in your web browser to open the NI Web-based Configuration & Monitoring Utility.
    • For LabVIEW versions earlier than 2013, navigate to localhost:3580 instead.
  2. In the top right corner look for Select Configure Settings (cog icon) and then select Web Server.
  1. Select the Web Servers tab
  2. Enable SSL (HTTPS) Enabled and select Save.
    • A system restart may be required before the change takes effect.
  1. Select Groups
  2. Under Open Certificate Signing Requests, select Add (+) a certificate signing request.
  1. Complete the New signing request dialog.
    • The Certificate Signing Request (CSR) and KEY files will be generated in your PC in the following location C:\ProgramData\National Instruments\certstore\open_csrs
    • Certificate requests follow the syntax server_XXX.csr where "XXX" is arbitrary number.
  1. Once generated the CSR and KEY files you can follow one of the following options:
    • Send the files to your IT department or PKI service provider to be signed by the certificate authority (CA).
    • Self-sign the CSR file using OpenSSL
      1. Navigate to C:\ProgramData\National Instruments\certstore\open_csrs and open a Command Prompt terminal in the same location.
      2. Run the following command to self-sign the CSR file openssl x509 -req -days 365 -in server_101.csr -signkey server_101.key -out server_101.crt
  1. Once generated the certificate (CRT) file return to the NI Web-based Configuration & Monitoring Utility tab in your web browser and go to Groups menu.
  2. In Open certificate signing requests option select your recently created signing request and select Install Certificate.
    • You will be prompted to select the signed certificate (CRT) file
  1. Once the signed certificate (CRT) is accepted, it will appear under Self signed certificates
  1. Now search for Web Servers menu and select the new signed certificate
  2. Selecte Save
  3. Reboot your PC to make changes effective
After completing these steps, the System Web Server and Application Web Server use the selected SSL certificate instead of the default certificate.
