Enable Results Collection for a Single Step in a Subsequence in TestStand
Updated Nov 14, 2018
  • TestStand
I want to include the results of a single step in TestStand, but the step executes in a Subsequence called using a Sequence Call step.. How can I enable the results collection for that step so that it shows up in the report without including the results for all the steps in the Subsequence?
  1. Select the Call Sequence step in the calling sequence and
  2. Select Step Settings >> Run Options .
  3. Set the Result Recording Option property to Enabled.
  4. Launch the Properties Dialog for the subsequence.
  5. Select the General tab and Disable Result Recording for All Steps in the subsequence.
  6. Click OK to close the Properties Dialog.
  7. Selecting the step fro the subsequence you want to enable results for.
  8. Set the Result Recording Option property to Enabled (override sequence setting).
In step 3, if all results are disabled to the calling sequence, you will also need to use the Enabled (override sequence setting) value for the Result Recording Option.
