Matching DIAdem and FlexLogger FFT
Updated Nov 14, 2018
  • FlexLogger
  • DIAdem
I am doing a fast Fourier transform (FFT) in FlexLogger and it is not matching the FFT that I am seeing in DIAdem. What type of FFT is FlexLogger using so I can match the two?
The DIAdem FFT Function type "Power spectrum", is the best match for FlexLogger's FFT Graph, with the FlexLogger FFT Graph Y-axis scaling setting "Output in dB" deselected (also known as "linear" scale).
One important thing to note is that the FFT in FlexLogger is being processed on the most recent set of data while that in DIAdem is the entire dataset that you import.
