Simultaneous CAN Input and Output on Same Port in VeriStand
Updated Nov 13, 2018
  • PXI CAN Interface Module
  • VeriStand
  • NI-XNET
Can I set up an input session and an output session on the same port of my NI-XNET device in VeriStand?
Yes, you can run input and output sessions at the same time in VeriStand. This can be achieved by setting up Input frames and Output frames on the same CAN port in the System Definition file, as seen in the image below.
