Get Required LabVIEW Licenses to Run a VI
Updated Nov 13, 2018
I am building an application in LabVIEW and I want to know which license do I need to get to have it working.
The LabVIEW License you require depends on the modules and toolkits that you use.
For example, a VI that uses the Report Generation Toolkit will require LabVIEW Professional or the Report Generation Toolkit add-on.
Use the following list of resources to guide your deployment:
National Instruments recommends documenting your application with the license requirements it has, depending on the VIs you use.
