You can use any C-Series temperature input module as long as the resistance range you will be working in is covered by the resistance range that the module supports. For example, the 9219 has a resistance range from 505 Ohms to 5050 Ohms, so if you will be working with your RTD at temperatures that will cause it to have a resistance in that range, you can use the 9219.
In order to do the acquisition, you would need to create a
resistance task and then convert the resistance measurement into a temperature measument, using the
Callendar-Van Dusen equation with the coefficients of your RTD.
