How To Get the SequenceFilePreStep Result In The Main Sequence Step?
Updated Mar 2, 2019
  • TestStand
I need to read a property from which is generated in the SequenceFilePreStep callback but I need to read it in the Main Sequence step (for example I need to log it in the report and Callback results are not logged in the report, so before I need to take the property in the Main Sequence).
The SequenceFilePreStep Results are available in the MainSequence Result List with the following hierarchy:
For Instance, in the previous image case, you can get the property of the SequenceFilePreStep with the following expression: Locals.ResultList[1].TS.SequenceFilePreStep.ResultList[0].Numeric
