Reading the External Calibration Integrity Checksum Property in LabVIEW
Updated Nov 16, 2018
  • PXI Digital Multimeter
  • PXI Oscilloscope
  • System Configuration
NI Measurement & Automation Explorer (NI MAX) shows an Integrity Checksum property in the External Calibration section of my device's information. Is there an API that can read this checksum?
You can read the Calibration Checksum as shown in NI MAX using the System Hardware Property Node from the System Configuration API. The Calibration Checksum property can be found in The property node in Devices & Chassis >> Calibration, as shown in the screenshot below.
The attached Read Calibration Checksum.vi exemplifies how to use the System Configuration API to retrieve a session for a device, based on its name on NI MAX, to use with the System Hardware Property Node to read the Calibration Checksum property.
