Indexing TDMS Files in DIAdem
Updated Nov 19, 2018
  • DIAdem
I want to load several TDMS files using DIAdem and organize the data in hierarchical way.
If I load two TDMS files, it goes directly to the same data storage root.
In order to load multiple TDMS files in hierarchical way, you need to change the separators to Semicolon in DIAdem settings.
You will see that the data storage will be organized with indexing.
NOTE: This option will not add another data storage root.
