The Vision Development Module performs only image processing. For image acquisition you will need Vision Acquisition Software.
Currently there is no Vision Acquisition Runtime Engine, so you will need to add via
Additional Installers one of the complete set of drivers from the Vision Acquisition Software (NI-IMAQ,NI-IMAQdx or NI-IMAQ I/O), depending on the hardware that you are using in your application. To identify the correct driver to add, see
Differences Between NI-IMAQ, NI-IMAQdx, and NI-IMAQ I/O.
