Can't Find DAQmx Installer When Building an Installer in LabVIEW
Updated Nov 9, 2018
I am attempting to build an installer for my LabVIEW executable application.  When I try to select build I am prompted to specify a folder location for DAQmx 18.1 installer.  I tried to point to the path that is specified for DAQmx in MAX but a window popped up that said it could not find the installer in the folder.
Updating to the newest version of DAQmx will save a local copy of the DAQmx installer. This will allow you to build your installer including DAQmx.
This issue occurs when there is no local copy of the installer on the computer.
