Communicate Two TestStand Sequences Using LabVIEW
Updated Nov 8, 2018
  • TestStand
I have two computers which are running different test sequences. These test sequences should communicate with each other in some steps. I am using LabVIEW with my application. How can I make this communication happen?
There are multiple ways to connect two LabVIEW applications so they can talk to each other. Use these communication techniques to develop your connectivity between sequences:
  1. Using Shared Variables
  2. Using SystemLink Cloud's Messages API
  3. Using LabVIEW's VI Server
  4. Performing low level TCP or UDP communication
  5. Using a Web Service
You can find more options to connect between a Host PC and a Distributed application in the following white paper: Understanding Communication Options Between the Windows HMI, RT Processor, and FPGA (refer to the section 6. "RT/HMI Communication")
National Instruments recommends not depending on more than machine running a test sequence to ensure maximum reliability.
If you require connecting to a server's database to log results, please consider using the built-in TestStand reporting options instead.
