Error -2147137023 An Internal Fault Occurred When Using a CANopen Module
Updated Jul 18, 2025
  • cRIO-9039
  • NI-9881
  • cRIO-9035
  • PXI-8531
  • LabVIEW Real-Time Module
I am using the NI-9981 CANOpen module inside a CompactRIO / when using a PXI-8531. After successfully compiling an FPGA VI with the module in the project and running the RT code, I receive the following error:
Error -2147137023 occurred at CANopen Emergency Create.vi:6970001
Possible reason(s):
An internal fault occurred in the NI-IndCom for CANopen driver. Contact National Instruments and provide the copErrorLog.log file. On VxWorks and Phar Lap ETS, this file is under C:\ni-rt\config. On NI Linux Real-Time, this file is under /var/local/natinst/nicanopen. On Windows7 or Windows Vista, this file is under C:\ProgramData\National Instruments\NI-IndCom for CANopen\. On Windows XP, this file is under C:\Documents and Settings\All Users\National Instruments\NI-IndCom for CANopen\.
This error can come from the FPGA registers required for the NI 9881 to function as being closed while running the CANOpen API. To avoid this error, you must open your reference and leave it open until the end of your code.
  • Ensure that the FPGA bitfile is running before creating the CANOpen Interface and do not reset or close the FPGA reference until the CANOpen interface is closed.
  • Also, monitor the CompactRIO CPU and memory usage , as a lack of these resources could cause a similar error.
If the issue happens on the PXI target, the reason for it can be the lack of resources in the system. You can use the following configurations of the BIOS to possibly avoid the error.
 - Platform Misc Configuration
  - Native PCIE Enable -> Enabled (this boosts up the data throughput of the connection and boosts the communication)
 - PCH-IO Configuration
  - PCIE Wake -> Enabled
  - PCIE Device Initial Delay -> 1
After verifying the above, as per the error message, provide the copErrorLog.log through your normal NI support channel for further analysis.
The FPGA bitfile needs to be opened in order to open low-level access registers, despite not having user access when running the 9881 CANOpen API in hybrid mode.
