Non-linear Waveforms in DIAdem
Updated Nov 6, 2018
  • DIAdem
Is DIAdem able to handle waveforms with a non-linear x axis (non-constant time step)?
DIAdem is able to work with waveform data where the timestamp is stored with the data values. See Waveform Channels - DIAdem Help .
These waveforms can only use uniform time steps. The timestamp is stored in the form of a start time and a constant time step.
To use a non-linear time step, create a channel with the time values and then plot the data values against this time channel.
