How Can I Detect If the User Changed in Teststand
Updated Oct 9, 2026
  • TestStand
When I login as a technician in TestStand, then login as an operator without the technician logout. The operator can still have some of the privileges of the technician.
The UserChanged Event can be used to detect when a user login without the other user logout. You can override a Callback so that when the event happens you programmatically close the Sequence File.
