The LabVIEW FPGA Module is only compatible with Windows.
If you need to use the LabVIEW FPGA Module in your macOS system, you could use the following:
- Create a Windows virtual machine with virtualization software.
- Use Boot Camp to create an additional partition and run Windows on it.
