Failed to Connect SSHD in Eclipse IDE Using myRIO
Updated Feb 19, 2019
  • myRIO Student Embedded Device
Programming Language
  • C++
Other
C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition
I am connecting Eclipse IDE to NI myRIO controller via SSH, but it resuts with "Failed to connect sshd on "172.22.11.2:22" error.
Switch on SSH or check that SSH is enabled on your target.
Based on Getting Started with C/C++ Development Tools for NI Linux Real-Time​​, Eclipse Edition ​​tutorial you should ensure your target has secure shell (SSH) enabled. You can enable SSH on your target using Measurement & Automation Explorer (MAX).
