Error -307735 When Adding DAQ Card to VeriStand
Updated Nov 2, 2018
  • cRIO-9045
  • cRIO-9048
  • cRIO-9041
  • cRIO-9043
  • VeriStand 2018
When I try to add a DAQ card in a 904X series combo chassis to my system definition, I get error -307735. Why is this happening? Can the combo chassis be used in VeriStand?
The 904X CompactRIO combo chassis that use NI-DAQmx is only compatible with VeriStand as a normal CompactRIO target. It is not yet able to support the NI-DAQmx functionality.
