Triggering Doesn't Work in DAQExpress 2.1
Updated Jul 24, 2019
  • DAQExpress 2.1
I'm trying to configure an analog input task to use a start trigger. When I set it up, I get an error message that says to specify a different clock type, though I have enabled 'Auto Managed Timing' to set up the use of the Sample Clock. How do I configure the task properly in DAQExpress 2.1?
This is a known issue in DAQExpress 2.1, which was fixed in the version 3.2 and higher
If you cannot upgrade to DAQExpress 3.2 or higher you can also downgrade to version 2.0.
