Why Can I Only Choose Select Values for the Configuration:Enabled Channels Property with the niUSRP Driver in LabVIEW Communications
Updated Nov 12, 2018
  • LabVIEW Communications System Design Software
  • NI-USRP
The Enabled Channels Property is an enum which only has values for [0], [1], and [0,1] in LabVIEW Communications.  This means that other configurations are not supported by the Property Node.  How can I use other configurations?
If you used the attached gVI file niUSRP Enable Channels.gvi, you will be able to use a string input for the Enabled Channels property, allowing you to use any configuration.  For example, when creating an niUSRP Session with two USRP RIO devices, you can set the enabled channels to 1,3 which will enable channel 1 on device 0 and channel 1 on device 1.  An example of this is linked in the Related Links section below.
