By default, the GPIB-ENET/100 attempts its network configuration through DHCP. A steady yellow PWR/RDY LED indicates that the device has passed its self-tests, has acquired an IP address, and is ready to operate.
If you do not have DHCP or wish to set a static IP address, follow these instructions:
- In MAX, right-click on the appropriate GPIB-ENET/100 or GPIB-ENET/1000 item and select Device Configuration.
- In the NI Ethernet Device Configuration Window, click on the device that you want to modify.
- Select Properties to change the network settings of this device.
