Creating a New Directory Each Time I Run My LabVIEW Code
Updated Jan 3, 2019
I have data that is being stored as I run tests in a loop. I want this data to be stored in a new directory each time I run the program, so that the data doesn't get overwritten. How do I create a new directory each time I run my program?
To create a new folder each time you run the program, you need a loop like the one below to check for created directories and creates the first one that it doesn't find.
