Using a Gauge With a Different Resistance Than Specified With My PXIe-4331
Updated Nov 30, 2018
  • PXIe-4331
I want to use a strain gauge with a resistance value that is not listed on the PXIe-4331 datasheet. Is there any reason this is not possible ?
The values listed on the datasheet are for internal bridge completion. It means that if you are using the quarter-bridge or half-bridge configuration, the PXIe-4331 will not be able to complete the bridge with the hardware it has available. If you are using the full-bridge configuration, those completion resistors are not needed anymore, and there is no technical reason that it would not work correctly.
