Error -375936 When Using Virtualbench
Updated Nov 8, 2018
  • VB-8012
  • VB-8034
  • VB-8054
  • NI-VirtualBench Application and Driver
The error occurs when I turn on NI VirtualBench application on my host PC. How can I deal with this problem?
Code: -375936
Description:
NI-VirtualBench: Power supply initialization failed.
This problem can be solved by software reset or hardware reset.
You can follow the steps below:
NI Measurement & Automation Explorer(MAX)
  • Launch NI MAX
  • Expand Device and Interface tab. Find and click Virtuabench device
  • Click the Reset and Self-test in NI MAX panel
VirtualBench Factory Reset
  • Press and hold the Reset button for longer than 5 seconds. The reset button is located on the back side of the VirtualBench as shown below.
  • Then release the Reset button and wait until restart.
  • The error will be solved.
Note: If you can not solve this problem with the above solutions, your instrument could be in abnormal status. Please contact local NI Support for further assistance or RMA.
