Do I Need to Calibrate My cDAQ Chassis?
Updated Oct 7, 2024
  • NI CompactDAQ Chassis
I have a NI cDAQ system that needs to be properly calibrated. Is the chassis a component that also requires calibration?
While the chassis does not control the data acquisition, signal conditioning, and output control, it will provide timing for the individual modules. Depending on your calibration and timing requirements, it may be necessary to calibrate the timing chips on your cDAQ chassis.
It is best to review the product manual for your exact cDAQ chassis for recommended calibration intervals and procedures.
For more information you can refer to theĀ CompactDAQ Chassis Calibration Procedure .
