Packed Project Library Namespace Uses Build Spec Name Instead of Selected File Name
Updated Nov 13, 2018
I'm building a Packed Project Library for inclusion in other projects. The build specification name and the target filename are two different things. When I try to open the packed library, it's searching in the namespace of the build specification name instead of the file name as shown in the picture below. How do I fix this error?
Create a new build specification with the same settings as the non-working one:
  1. In the project window, right click Build Specifications and select New >> Packed Library
  2. Configure the new Build Specification in the same way as the previous one, though the build specification name must be unique.
  3. Build the new packed project library, and when you open it it won't have the same error.
