Signal Express Gets Stuck Loading When Opening
Updated Nov 13, 2018
  • SignalExpress
I opened SignalExpress and all of my custom scales had disappeared. When I open Signal Express, it gets stuck on the Loading step of initialization. I also tried to open NI MAX, and it didn't get past the Initializing step. How can I put my SignalExpress back into working order?
Reinstall the NI-DAQmx driver in order to fix SignalExpress.
If this doesn't work, you may have to reset the NI MAX database following these instructions: How to Fix or Reset the NI MAX Database File.
