How Do I Stop NI License Manager Requesting Particular Software?
Updated Feb 21, 2023
  • NI License Manager
  • Volume License Manager
I am using NI Volume License Manager to manage license permissions. How can I stop clients from requesting permissions to specific NI software packages or modules?
If you have a Concurrent License, you can prevent a computer from using a specific network license using the option Do Not Allow License Request.
  1. Open NI License Manager on the client computer.
  2. To prevent using a specific network license, right-click on the product listed under a network license server and select Do Not Allow License Request. You can also select the product listed under a network license server and click Disable.
  1. If you need to access the license again, right-click on the blocked product and select Allow License Request or select the blocked product and click Enable
If you want to apply this to multiple clients you can write a script to edit the checkout behavior with the following steps:
  1. Open up the servers.ini file located at C:\ProgramData\National Instruments\License Manager\Data\
  2. Add the following line to your server configuration file
    • BlockedFeatures = <package_name>;
  3. You can find the name of the package you wish to block by opening the license file with any text editor.
  1. Replace <package_name> with the name you found in Step 3.
You can restore the original state by deleting the BlockedFeatures = <package_name> line from the servers.ini file.
