Can I Use a cDAQ Controller with a USB Printer?
Updated Oct 24, 2018
  • CompactDAQ Controller
  • Windows Embedded Standard (WES)
I am designing a system that will use a cDAQ controller running Windows Embedded Standard 7 (WES7). I would like to know if the hardware, as well as the Operating System can support a USB printer.
The limiting factor to determine if your printer will work with your controller is the printer's driver compatibility with Windows Embedded Standard 7 (WES7).
  • Please refer to your printer's specification sheet to view the list of compatible Operating Systems and make sure WES7 is on the list.
The USB host ports on a cDAQ controller can accommodate common USB devices. Thus, the hardware will not be a limiting factor.
