このコンテンツは設定された言語で表示できません。
Ethernet cDAQ Loses Connection to Router in Link Local Only Mode
Updated Feb 4, 2025
  • cDAQ-9181
  • cDAQ-9183
  • cDAQ-9184
  • cDAQ-9185
  • cDAQ-9187
  • cDAQ-9188
  • cDAQ-9189
I have an Ethernet cDAQ device configured in 'Link Local Only' mode and connected to my router. My host PC connects through the same router, but it cannot see the chassis. What can I do to see my network cDAQ chassis?
Some routers have a Proxy ARP  feature. This feature is enabled by default. When enabled the proxy-APR may cause the cDAQ and host PC to not be able to communicate effectively when the cDAQ is configured for 'Link Local Only'.
You can remedy this by using one of the following configurations:
If you must use your Ethernet cDAQ in Link Local Only mode when connected to a router, NI recommends disabling the arp-proxy or Proxy ARP feature on your router to ensure proper operation.
