You can press the
space bar while placing a line in a copper layer, this will toggle between orthogonal, diagonal, 45 degree, and any angle lines.
Alternatively, in the Customize dialog box an Any Angle Lines is available, complete the following procedure to add this option to your user interface:
- From the main menu select Options» Customize Interface
- Select Place from the Categories listbox
- Put your mouse cursor on Any angle lines from the Command listbox. Hold the left mouse button down and you should see a small rectangle attached to your mouse cursor
- Continue to hold the left mouse button down and drag the rectangle over Place main menu to expand it.
- Drop the rectangle in the Place menu
