How to Set Up CompactDAQ Controllers with Windows Embedded System
Updated Jul 13, 2026
  • cDAQ-9132
  • cDAQ-9133
  • cDAQ-9134
  • cDAQ-9135
  • cDAQ-9136
  • cDAQ-9137
  • Windows Embedded Standard (WES)
I have a brand new cDAQ controller and I want to set it up. I connected it to my computer but I cannot access it and install drivers or any kind of software components. How can I set up the device?
Is it possible to use an external PC as a host instead of the built-in Windows 7 controller to enhance device capabilities?
The cDAQ-9132/9133/9134/9135/9136/9137 for Windows ships with preloaded Windows Embedded Standard System. This means, that to be able to set up the device, you have to connect the appropriate interfaces.
Interfaces:
  • Computer mouse and keyboard
  • Monitor with Compatible mini DisplayPort cable (and adapter if necessary)
Installing steps:
  1. Connect a video monitor to the mini DisplayPort connector with a cable (and adapter if necessary).
  2. Power on the monitor.
  3. Connect a computer keyboard and mouse to the USB host ports on the cDAQ controller.
  4. Turn on the external power supply.
  5. When the cDAQ controller powers on, the POWER LED lights and the controller runs a power-on self-test (POST). When the POST is complete, the operating system is loaded.
  6. Go through the steps on the Set Up Windows screen that opens on your monitor. Windows prepares your desktop.
Devices part of the cDAQ-913x family are stand-alone solutions, which means that it is not possible to bypass the built-in Windows 7 Controller with an external PC, if this is part of your requirements consider using another CompactDAQ chassis without an embedded controller that can connect to a host PC through Ethernet or USB.
