Este contenido no está disponible en su idioma de su preferencia.
El contenido se mostrará en otro idioma disponible. Su navegador puede proporcionar una funcionalidad para ayudarle a traducir el texto.
How to Set a PXI Controller to Start Automatically When Powered
Updated Jun 23, 2025
  • PXI Chassis
  • PXI Controller
How can I set a PXI controller to start up automatically when power is applied?
Before applying these changes, please review whether your controller supports the Restore After Power Loss. This information can be checked in the controller manual. To access it, please review the NI Product Documentation Center.
1. Press the Power button on the PXI chassis, then press Del on the keyboard repeatedly to enter the BIOS.
2. Switch tabs to Advanced and select Power/Wake Configuration as shown below.
3. Select Restore After Power Loss and select Turn On as shown below.
4. Select PXIe Backplane WAKE# and select Enabled as shown below.
  1. Press F10 on the keyboard and select Yes to save the configuration and restart the controller as shown below.
  2. Make sure that the Inhibit Mode Switch on your PXI chassis backplane is set to OFF. You can find more instructions on the DIP switch in the User Manual of your device.
With this configuration, the PXI chassis and controller will automatically power on when power is supplied.  This includes when power is lost and is restored.
