Power Concerns for Using PCI/PCIe Cards With 240V Powered Computer
Updated Oct 17, 2018
  • PCIe-6351
I have PCI/PCIe cards that I've developed in a machine that can use either 110V power or 240V power. Should I be concerned about the cards if that system is deployed in a place that uses 240V power?
As long as the computer is capable of running on 240V power, the power supply of the computer should be able to regulate the power supplied to the PCI/PCIe cards.
