Plot Channels by Name in DIAdem
Updated Nov 22, 2018
  • DIAdem 2017
  • I created my report to generate graphs in DIAdem. When I put my input data in the different order the report is not correct. Is there a way that the report would refer to that name of the channel instead of its position?
  • Is there a way to plot the channels by name in DIAdem?
32-bit DIAdem (refer to DIAdem 2017 Help )
  1. Go to Settings»DIAdem Settings»Compatibility and disable REPORT channel references refer to the structure view of the Data Portal.
  2. Go to section Name-oriented channel references in Settings»DIAdem Settings»General and choose Only channel name in scroll-bar.
64-bit DIAdem
NOTE: You can not get only Channel name without Group name in the 64-bit version.
  1. Go to section Name-oriented channel references in Settings»DIAdem Settings»General and choose Group name/Channel name in scroll-bar.
