This is a known issue found in LabVIEW, some listboxes type would revert back to the default size even though they are already saved. Based on the LabVIEW version, this applies to either
Tables, list boxes, and multi-column listboxes or
Listbox (Modern) and
Listbox (NXG Style). Depending on the LabVIEW version, we could apply the following work around:
LabVIEW 8.0, 8.0.1 and 8.20We can use the
Index Values property to programmatically scroll the table/list control. Using boolean buttons instead of a scrollbar, you can increment/decrement the Row and Column values of the Index Values property. The zip file below contains a VI which shows an example of how to do this. Place the "parallel loop" in your existing application and use property nodes to manipulate your existing table controls. This loop is shown below
LabVIEW 2009 or LaterWe can use
Listbox (Silver) for this scenario, as it is also designed to address the need of customizing the width of the scrollbar.
