Module Creation Conflict When Discovering C Series Modules in LabVIEW Project
Updated Oct 30, 2018
  • CompactRIO Chassis
  • cRIO-9035
  • LabVIEW Real-Time Module
  • LabVIEW FPGA Module
When I try to discover the C Series Modules connected to my CompactRIO chassis in a LabVIEW Project using either the Scan Mode or the FPGA Interface, it shows the following error:
Module creation conflict. The session is invalid. The target may have reset or been rebooted. Check the network connection and retry the operation.
Try the following steps:
1- Verify your Ethernet connection isn't faulty. Try a different Ethernet cable, port, switch.
2- Reformat and reinstall the software in your cRIO.
