Unresolved Dependencies Error When Installing Software on NI Real-Time Target
Updated Apr 27, 2026
  • CompactRIO Controller
  • LabVIEW Real-Time Module
  • I'm trying to install software to my Real-Time PXI Controller, and I receive the following error:
Cannot continue because of the following unresolved dependencies:
NI Web-based Configuration and Monitoring 11.5.0 requires NIAuth Web Services 11.5.0
NI System Configuration Remote Support 5.1.0 requires NIAuth 2.0.0
  • I am trying to install software onto my cRIO or onto a module in the cRIO (such as NI-9149) but I get the following errors in NI MAX.
NI System API 18.1.0 requires Base System 10.0
NI System API 18.1.0 requires LabVIEW Real-Time 13.0
Possible reason: The feature's Real-Time support for this target for this target type may not be installed.
This issue occurs when there is either a software version mismatch between the host PC and the Real-Time (RT) target, required software is missing from the host PC, or there is a software corruption on the RT Target preventing from installing new packages. To resolve this, take the following steps:
  1. Install the LabVIEW Real-Time Module version corresponding to the current LabVIEW version on the host computer.
  2. Install the software on the host PC which is recognized as missing or required during installation by NI MAX.
  3. If the required software is installed on the PC, remove all the software from the cRIO by selecting Uninstall all software in NI MAX. Afterward, begin the installation again by selecting all the required packages to be installed together.
Another potential cause is, if BIOS is incorrectly installed when you are migrating controller OS from NI Phar Lap ETS or Windows to NI Linux Real-Time, the issue can be occurred too.
Kindly ensure that you follow the correct installation steps mentioned in this article: Provisioning a Controller With the NI Linux Real-Time Operating System by checking the minimum BIOS version for NI Linux Real-Time support for the specific controller.
