TestStand Environment Reverts to Default When Launching TestStand File Diff/Merge Application
Updated Nov 9, 2018
  • TestStand
I am using multiple TestStand Environments so each TestStand Environment can independently maintain its own station globals, type palettes, and customized process models.
However when I am clicking Edit -> Diff Sequence File Against option the opening window is always in default <Global> Environment.
How can I overcome this issue?
When you are clicking on Diff Sequence File Against the TestStand File Diff/Merge application is being launched. The location of this executable if you are using 32-bit version of TestStand is normally:
'C:\Program Files (x86)\National Instruments\Shared\TestStand\FileDifferLauncher.exe'
In case you are using the 64-bit version:
'C:\Program Files\National Instruments\Shared\TestStand\FileDifferLauncher.exe'
This executable can be launched with different parameters and the Environment is one of them. By default there is no parameter value for the Environment thus the <Global> Environment is being launched. However you can define the Environment by running the application with a parameter. This parameter should be a reference to the file path of the required Environment file.
Add this to the executable shortcut:
 /env <environment path>
You can list the available parameters of this application using the following line in the command prompt:
"C:\Program Files (x86)\National Instruments\Shared\TestStand\FileDifferLauncher.exe" /?
