Controls and Indicators are Transparent on my Web Application on NXG
Updated Oct 25, 2018
  • LabVIEW NXG
On LabVIEW NXG, I tried to work on a Web Application Project. My problem is when I try to add some controls or indicators on the interface, I can't see them. They appears on the diagram but not on the interface. I can only see the shape as you can see on the picture below:
To fix this problem, go on the Network Proxy Settings on your windows computer. Then, you must enable Don't use the proxy server for local (intranet) addresses as shown on the picture below (this screenshot is for Windows 10). This change will allow you to see your controls and indicators on the front panel.
