How Can I Deploy VBAI Inspection?
Updated Apr 25, 2019
  • Vision Builder for Automated Inspection
I need to deploy vbai file, which was developed in Vision Builder AI, to an end user computer station. How could I compile EXE application from VBAI to restrict changes in vision inspection file?
If you deploy inspection, then you need to install Vision Builder AI on the operator’s PC and activate Vision Builder AI Run-Time License instead of VBAI Full Feature.
Run-Time VBAI does not allow add, delete steps, states, and transitions in inspection or create new inspections.
Vision Builder for AI does not support compilation into EXE application. If you need to exactly EXE file, then you need to use LabVIEW application develpment environment to build it.
You can use migration procedure a Vision Builder for Automated Inspection Script to LabVIEW for that.
