Does NI-XNET Support the FlexRay Database in AUTOSAR XML Format?
Updated Jul 30, 2019
  • NI-XNET
When opening an AUTOSAR XML (*.arxml) file using the NI-XNET Database Editor, I can see and edit CAN-related clusters but not FlexRay clusters. Why? There is no error or warning.
The *.arxml format is not supported for FlexRay databases in XNET. Currently, to view or edit FlexRay clusters in the NI-XNET Database Editor, you must use an XML-formatted database.
​Beginning with NI-XNET 17.0.1, XNET started to support database files in *.arxml format. However, this only applied to CAN databases until support for *.arxml LIN databases was added in XNET 17.5.
