How to Create a FTP Server Folder in LabVIEW
Updated May 4, 2023
  • LabVIEW Professional
  • LabVIEW Base
  • LabVIEW 2012 Internet Toolkit
I want to create a folder on the FTP servers for file management. How can I create folder programmatically with LabVIEW?
Before LabVIEW 2012
If you install the LabVIEW Internet toolkit in LabVIEW 2012 or earlier, there are several FTP functions available on the Functions palette, including VI which creates FTP folder.
After LabVIEW 2013
Starting with LabVIEW 2013, the FTP function is automatically installed in the Base, Full, and Professional Development systems. However, when you look at the Functions Palette»Data Communications»Protocols»FTP, you can notice that VI which creates FTP folder does not appear.
Therefore, you must access the FTP library directly through the following path and use VI to create an FTP folder.
1. Access C:\Program Files(x86)\National Instruments\LabVIEW 20xx\vi.lib\FTP.
2. Click the NI_FTP library
3. Use FTP[MKD].vi in FTP1.llb.
If you open FTP[MKD].vi, it is configured as below and you can use it to create a folder on FTP server.
MKD is a command to create a folder of FTP server. If you want to know additional FTP commands, you can reference in the external Link: List of FTP commands.
