Are LabVIEW Code Modules Called with Administrator Privileges?
Updated Oct 9, 2018
  • TestStand
When I run TestStand I choose to open it with administrator privileges for the Windows, does this mean that the LabVIEW Code Modules will also be running with the same privileges.
Yes, if you run TestStand with administrator privileges then the LabVIEW code modules called in the sequence will also be run with the same level of privileges, this is true whether you are using the LabVIEW Run-Time Engine or the development environment to run the VIs.
