This is related to a known error that is being worked at the moment. As a work around, you can go to you Build Specs of your Main VI. Go to the properties. Then under "Additional Exclusions" uncheck the "Disconnect type definitions." When that's unchecked, it should work. Otherwise, you can replace the channel wire with a queue.
