What Does the Status Column in the Search Directories Dialog in TestStand Indicate?
Updated Dec 3, 2018
  • TestStand
When I configure my search directories in TestStand by going to Configure>>Search Directories, I see a Status column. What does it indicate?
The Status column is used to keep track of any directories that are listed in the Search Directories. If a directory is not found or is not accessible at the point of opening the Search Directories window, the Status will display Not found.
Once the directory can be found again, the Status column for that directory will revert back to empty. This allows TestStand to keep the search directories list consistent, even if some are not currently accessible.
