Integrating Python Code in LabVIEW
Updated Dec 11, 2020
Programming Language
  • Python
I'm trying to integrate code developed in Python to LabVIEW. Can I do that?
LabVIEW 2018 introduces the Python Node, which provides native capability to intuitively call a Python script from a LabVIEW Block Diagram. It uses LabVIEW primitives, providing a way to interoperate between the languages with low latency.
This will only work for LabVIEW 2018 or newer versions. Check considerations for installing Python for using with the LabVIEW Python functions.
Examples for using the Python Node are available in the LabVIEW Example Finder (found in Help >> Find Examples...) under Communicating with External Applications >> Using External Code >> Integrating Python Code.
