Can I Run a LabVIEW Executable From My Server?
Updated Oct 10, 2018
  • LabVIEW Run-Time Engine
What are the considerations when running a LabVIEW executable using multiple client computers (with the LabVIEW Run-Time Engine installed) from my server?
This method should be fine, just be careful about allowing multiple instances to modify any data at the same time.
The LabVIEW Run-Time Engine will create a local instance of the LabVIEW EXE, and run this on the local computer.
