Can InstrumentStudio Run in Parallel with LabVIEW?
Updated Oct 18, 2018
  • InstrumentStudio
  • LabVIEW NXG
  • TestStand
  • NI-DMM 18.1
  • NI-SCOPE 18.1
  • NI-FGEN 18.1
  • NI-DCPower 18.1
Can I use InstrumentStudio alongside LabVIEW without resource conflict errors?
If you have tried to access an instrument from both a programming environment and a Soft Front Panel simultaneously in the past, you may be familiar with errors along the lines of "resource conflict" or "instrument already in use". Now you can run in parallel InstrumentStudio and LabVIEW or TestStand without any error. You just need to upgrade your drivers below to the 18.1 version or higher:
  • NI-SCOPE
  • NI-FGEN
  • NI-DMM
  • NI-DCPOWER
