Can I Connect Multiple Devices to USB-8476?
Updated Nov 5, 2018
  • USB-8476
Can I connect multiples devices to the same port of USB-8476 to create a LIN network?
The USB-8476 module is a 1-port LIN Interface Device for connecting PCs to LIN networks and devices. It offers software-selectable, master/slave termination, so you can monitor, log, and test at all points of a LIN network.
In a LIN network, you can have up to 16 devices on a single bus. As long as you follow the cabling requirements and bus power requirements, you can connect up 16 devices in the port of USB-8476.
